loose cassett cogs ...
[Closed] loose cassett cogs Shimano Hg-50
[#585594]
hi all.the bottom three cogs are loose on said cassett.
what prey tell may be the problem..cheers gang.
Posted : 27/05/2009 10:35 pm
Is this when its on the hub? tighten the lockring up
Posted : 27/05/2009 10:46 pm
yer on the hub..
Posted : 27/05/2009 11:42 pm
if that doesn't work, take the cassette off and check if the splines on the freehub are damaged/ bent - this can cause rings to wobble
Posted : 28/05/2009 12:41 am
