Has anyone got 1 m of spare gear inner liner they can spare please?
I've ordered some on ebay that was supposed to be in stock but it's not and going to take a while to get to me and I want to build the frame up. I can send some back to you when mine turns up.
Cheers.
By "inner liner" do you mean inner (cable), or outer?
Also where are you? Might be someone close enough to ride by on your one-a-day (non-personal handover of course!)
Cancel guys, postie came to the rescue!!
DezB, badly written by me, it's the lining sheath that I need to help with feeding the inner gear cable through a frame.
On with the frame built later on then 🙂
Thanks
t’s the lining sheath that I need to help with feeding the inner gear cable through a frame.
Ooh, that's a new one on me! Cool you're sorted anyway 🙂
And to me too, it's what someone recommened on my other thread, will find out tomorrow!
Granny_ring, what product did you order? I can find some Jagwire stuff but it's for brakes, does that matter?
Does it need to run all the way through the outers, or just where outer meets inner?
Am quite confuzzled by my Rose, the gear inner (and sheath) pops out above BB but then disappears back into chainstay, can't see any break in sheath..
I use something like this https://www.advancedfluidsolutions.co.uk/15mm-id-x-25mm-od-clear-transulcent-silicone-hose-pipe-tubing-2434-p.asp
Mine came with my canyon though.
Monk it sounds like your bike has full length internal outers, my specialized is the same. Makes cable changes super easy.
bike_discount.de appear to have loads, different lengths and brands, as well as the foam liner to stop the cables rattling off the inside of the frame (yes, I am that vain).
Appears much better priced than most other branded alternatives (I had to check you got 4 liners per pack, am still sceptical although they have confirmed in writing...).
https://www.bike-discount.de/en/buy/capgo-noise-protection-735647
https://www.bike-discount.de/en/buy/radon-teflon-liner-5000mm-871246
