Loco fork service
[Closed] Loco fork service
[#5223105]
Trying to pick the correct service for my 32mm Fox Floats with the FIT damper. Does the service include an oil change in the damper, or do you have to order the damper rebuild separately?
The blow-off threshold knob is stuck on mine through lack of use (I suspect it's simply corroded slightly since it's not a complicated mechanism), and I'm not sure that freeing it up again by using some muscle is the best approach.
Cheers,
Dave.
Posted : 06/06/2013 12:36 pm
