Locknut on Rear Hub...
[Closed] Locknut on Rear Hub Coming Loose
[#2729599]
I have a Shimano FH-M435 rear hub and after approx 300-400 miles the locknut is coming loose.
Has anyone else had similar, if so, how did you sort it?
Posted : 08/05/2011 6:30 pm
Anybody?
Posted : 09/05/2011 8:49 am
shimano hubs are tricky, to fix it yourself you will need 2 x 17mm spanners, a cone spanner (15mm?), some degree of mechanical sympathy, and about an hour to learn what you're doing.
basically, get the tools and tighten it up*.
or, phone a friend who can do it for you, and fill them with beer/tea/cake/tasty snack of choice.
i'll do it for you if you're in sheffield...
(*each cone + locknut need to be tightened against each other, [u]AND[/u] preset so that they're not too tight and not too loose - this is the tricky bit.
Posted : 09/05/2011 8:56 am
My First Meta Did this. Flexy swingarms act like a big spanner. It was either the locknuts or the qr coming loose. Bought a Dual-cam QR and locktighted the Locknuts which made it last a lot longer
Changed the hub to a 12mm bolt thru in the end. Sorry thats no help at all
Posted : 09/05/2011 9:25 am
It never has happened on any of my other bikes BTW. I blamed it on me being a 100kg+ lard arse stomping on the pedals and twisting that long swingarm...Even with locktight and locking the locknuts super tight to each other, you wouldnt believe it.
Posted : 09/05/2011 9:51 am
 rock
Had the same problem. Reassemble with loctite on the driveside nuts to ensure that it's only ever the non-driveside that comes loose
Posted : 09/05/2011 10:01 am
Thanks for the replies guys.
It is the driveside locknut that is working its way loose. Ill retighten tonight.
Oh and Dan I am 68kg 😕 so hope its not my weight 😉
Posted : 09/05/2011 1:36 pm
