I need a new D lock as my old one has finally bitten the dust.
Shackle must be double locking ie each end of the shackle. Shackle must be at least 16mm thick and case hardened. Needs to be about 25 cm long so it can go round street furniture.
anyone any clues?
Kryptonite New York M18?
Ta - Looks OK. I didn't realise they did an 18 mm shackle - the only ones I found were 13 mm but I have been wary of Kryptonite products since their poor response to two previous times their locks were found wanting
Got an abus granit x plus, only 13mm but absolutely solid and gets great reviews
Abus do make a d-lock with a 16mm shackle but I don't know how long it is and it's £230.
Ta Simon. The kryptonite is only £100. Mind you the one its replacing cost me £100 25 years ago
Abus Granit x can be cut with bolt croppers - needs to be at least 16mm if not 18mm to be boltcropper proof. I have one already but its only used when either I don't want to carry the weight or its somewhere secureish
I do leave bikes in the city centre quite often for periods of time so need something as close to unbreakable as I can
The cheaper Kryptonites are poor, the more expensive ones, as in the 'New Yorker' are good.
I've been using the Abus mini D for a few years in London. A solid lock that's too small to fit a jack inside but also too small to fit round a lampost. I also have an Abus 1000 cable lock that fits round my waist for anywhere i feel is dodgy. If you can double up it's good.
If i can find where I bought mine I'll post links.
I think that a battery powered grinder with a slitting disc is a bigger issue than bolt croppers now.
If you will be leaving the bike in a regular spot, leave a big beast of a chain a a well lubed shutter style padlock in the area for you to use when needed.
Wheels have security skewers, and torx security fasteners fitted to stem, top cap, seat post and saddle clamp. Sometimes you need to grind the heads down a bit to fit.
Abus Granite X Plus or Kryptonite New York are your two choices essentially.
devash Abus granit plus can be bolt cropped in seconds. the new yorker is just about good enough. 18 mm shackle is what you really need
Neilwheel - ta
The place where I bought mine are no longer carrying much stock.
IMO you need a bloody good tool to crop a 16mm shackle.
Agreed. 16 mm is difficult to crop. 18mm virtually impossible. 13 mm straight thru with croppers - assuming decent case hardened steel of course
Bolt croppers are the local neds tool of choice
almax have some scary testimonials and vids
OnGuard Brute? Almost too cheap (<£30) but get good reviews
Shackle Dimensions: 115mm x 260mm x 16.8mm (W x H x D)
Ta
Makes you wonder if the steel is poor or are the others overpriced
Check [url= https://www.lfgss.com/conversations/144109/ ]here[/url]. I have a few of [url= http://www.clasohlson.com/uk/Asaklitt-Shackle-Lock/31-2166 ]these[/url]; they're very good and an awful lot cheaper than the rest.
Someone tried to go through one at the station once. Hardly a mark on it
It's good to know what the local MO is.
Last year we had a gang who started cutting the bike hoops in broad daylight wearing high-vis work gear. Then they would put the cut section back using tape to cover the join, they could then just keep doing the rounds, removing bikes and then re-applying the tape.
Ta petec - I'd forgotten about that site
