Lion battery summer...
[Closed] Lion battery summer stowage
[#443990]
help me out if you can! do you know if i should stow my Lion Battery full charge or run it down and then stow away for the summer?
thanks.
Posted : 02/04/2009 3:49 pm
Smudge offa here told me to store at 80% charge.
Posted : 02/04/2009 3:56 pm
this is from Lumicycle website:
Store the the battery in a cool place (in the fridge is great....not the freezer!).
For best battery life store the battery at around 50% of charge.
To revitalize your battery after storage: charge fully. Use ½-¾ of battery. Fully recharge again. Your Li-Ion Battery is now ready to go!
Posted : 02/04/2009 4:00 pm
Sure he said 80% charge? 40% is the usual figure quoted.
Also, put it in the fridge.
Posted : 02/04/2009 4:03 pm
Half charge and in the fridge guys and gals.
Posted : 02/04/2009 4:06 pm
If a Li-ion runs completely flat it will not recharge. If you force it to recharge it may explode. The shelf life is determined by level of charge and temperature. More charge + high temp = shorter life. The self discharge of a lion is less than ni-mh but if you store it with too little charge it may fall below the point where it will charge back up again so its a compromise between not enough charge = dead battery or too much charge = shorter life.
you can read about it here if you have some matchsticks to prop your eyes open with.
http://www.candlepowerforums.com/vb/showthread.php?p=2873403
Posted : 02/04/2009 4:15 pm
this is a minefield guys & there is a lot of info on the net inc the fridge option which has been flawed by the experts on so many different accounts so avoid that advice.
Posted : 02/04/2009 9:16 pm
Keep it away from tigers.
Posted : 02/04/2009 9:38 pm
My battery guy said to store mine having fully charged then run the lgith for an hour or so, stick them in a ziplock and put them in the back of the cupboard. Sometime about temperature fluctuations etc.
Anyway, have always done that and they are all about 3 or 4 yrs old now and hold full charge and seem to last basically as long as they always have. Thats amix of 4.4ah and 6.something ah ones that I use with with my iBlaaaaaast or Endurenz as it was.
Posted : 02/04/2009 10:01 pm
