Lightweight Cranks?
[Closed] Lightweight Cranks?
[#7456963]
With 104 BCD? What's lighter than XTR? Anything out there that's not a fortune? I reckon I can sort myself out with some XTRs on eBay for about £60 ish if I take my time, just wondering if there's anything else out there?
Posted : 15/11/2015 9:48 am
Anything carbon? Maybe not the price but plenty lighter
Posted : 15/11/2015 9:50 am
 br
I don't know about more modern stuff, but there was only 50g (on my scales) between XTR (960) and XT (760), so it pays to investigate rather than assuming - especially real weights as opposed to manufacturers.
Posted : 15/11/2015 10:15 am
50 grams is 50 grams.....
Posted : 15/11/2015 10:18 am
 DT78
£60 for xtr? That's a bargain. Keep in mind some of the older ones had odd bcd and needed specific (expensive) rings
Posted : 15/11/2015 10:39 am
Definitely not. Some carbon stuff for sure. But like stems carbon cranks often aren't lighter.
For £60 you'll never beat XTR, and they're fantastic cranks. Do you want single, double or triple? Is £60 the budget, or just what you reckon you can get XTRs for?
Posted : 15/11/2015 10:43 am
 momo
M970 are hard to beat, just make sure they come with the fitting tools if you're buying on eBay.
Posted : 15/11/2015 11:02 am
I've some M960's to sell, I'd take £60
Triple, quite a new granny ring
Posted : 15/11/2015 11:10 am
I've got a set of aerozine x1 cranks. The chain ring attaches to the crank by 3 bolts so you need to run an aerozine Chainring. The adaptors mean you can run them at 170 or 175 (172.5 if you buy a different one)
Mine weighs 555g with chain ring so lighter than xtr.
I'm not using it at the moment as it's got a new 34t Chainring and it was a bit tough. I'm running an xt with 32t.
If I had the money I'd buy some Raceface next carbon cranks.
http://pages.ebay.com/link/?nav=item.view&id=131315496867&alt=web
Posted : 15/11/2015 12:15 pm
Then a chunky stw warrior swings a leg over and pedals away, cancelling out any weight saved.
Posted : 15/11/2015 12:34 pm
thats another cake at the trail centre that can be eaten though
oh and speak for your self on the chunky 😉
Posted : 15/11/2015 1:32 pm
I've got some XTRs for sale, can equip them with a Hope 32t Narrow/Wide or a 32t Oval from Absoluteblack.
In brilliant condition, with a newish XTR BB I could do the full set for £150
Posted : 15/11/2015 1:51 pm
The aerozine x1 uses the same spiderless system as the sram, so you can use none aerozine rings. It's a very light crank
Posted : 15/11/2015 1:55 pm
Rotor? XTR is probably your best bet though.
Posted : 15/11/2015 4:07 pm
Cheers all, not quite ready to buy yet. Making a list for my upgrades. Looks like XTR though.
Posted : 15/11/2015 4:41 pm
 gee
Unless you get a set of Next SLs there isn't really much point buying anything other than XTR. Light, reasonably cheap, last forever.
Posted : 15/11/2015 6:13 pm
The SRAM X01/XX1 carbon cranks are fairly light, plus you can take the spider off them. Don't know if they're lighter that XTR though.
FWIW when/if I change cranks on my xc bike I'll probably be getting some of the rotor inpower cranks.
Posted : 15/11/2015 6:32 pm
XTR M970 Arms Only (inc 4 arm spider) - 514g
Absolute Black 104mm BCD 32t Ring - 33g
4x Aluminium Chainring Bolts - 8g
SRAM XX1 GXP Arms only (No Spider) - 463g
XX1 4 Arm Spider + Bolts + Ring - 91g
XX1 DM 32t Ring - 63g
Absolute Black 32t GXP Ring - 52g
RaceFace Next SL inc 32t DM Ring - 446g
Posted : 15/11/2015 6:42 pm
Aye, 600g for Rotor 3D+ with QX1 ring and bolts, but it does have a 30mm axle if that floats your boat at all!
Posted : 15/11/2015 6:50 pm
My SRAM carbon cranks were fractionally lighter than my M970s, but that was offset by them being ****ing useless SRAM and having the BB wear out the first time rain was forecast.
M970 is a fantastic balance of price and performance tbh, very hard to beat for standard 24mm cranks. I'd love to get Next SLs for everything but that's never going to happen.
Posted : 15/11/2015 6:59 pm
