Light Bicycle / ea...
[Closed] Light Bicycle / easy with a track pump?
[#6798705]
Fancy some new carbon wheels that are "tubeless easy" with a track pump. Had Stans Crests and they were Very easy. Have some Sram Rail 50's and they won't go up without a compressor / not a technique thing as I found the Crests no problem. Have to resort to a tube inside to seat one side of the bead and a visit to the Lbs to use their compressor for the other side. Are the Light Bicycle Ok? Looking at the 30mm inside 650B version. Cheers guys and gals. Serial tyre swapper 😕
Posted : 21/01/2015 9:00 pm
Did mine a few days ago, all depends in tyre. rocket Ron went up with minimal effort
Posted : 21/01/2015 9:09 pm
Had lodsa different tyres on the Crest without a problem. Running a Magic Mary upfront and a Minion Dhf on the rear. Also have An Ikon and an Ardent. Lbs were suprised at how much effort it took seat on a "premium" wheel.
Posted : 21/01/2015 9:18 pm
Yes, very easy. Topeak mountain morph too.
Posted : 21/01/2015 9:43 pm
SRAM rail 50 are impossible to get up tubeless without a compresor
It's really annoying and shite given they are a grands worth of wheel almost
Never had any issues really with other rims but the rail 50s are shocking even worn tyres won't go up tubeless without a compressor
Let me know how you go on tubeless with the LB when you get em
Posted : 21/01/2015 11:13 pm
My lb 35mms were fine with a track pump once I lubed up the tyre bead
Getting schwable tyres on the rim was a right ballache tho !
Posted : 21/01/2015 11:48 pm
I've found the hookless ones a bit tricky because you can't seat the bead.. got it to go up eventually though.
Posted : 21/01/2015 11:49 pm
27.5 35mm hook less Lb. Easier than my crest rims with maxxis tyres.
Posted : 21/01/2015 11:58 pm
I needed several turns of tape on my 27mm hookless 29ers to get Schwalbes to seal. Worse after refitting tyres too - tape getting pushed into the well. Ended up putting some of that draught excluder foam in the well, with a layer of tape on top. Flatter profile, easier inflation.
Posted : 22/01/2015 9:11 am
My 35mm LB 29er hookless rims have been mostly fine. 2.4 Conti Trail Kings, 2.3 Maxxis Minion DHR2, WTB Vigilante's and the current 2.4 Magic Mary all inflated ok with just a track pump. I use a Joe Blow Max. The only tyres I had an issue with were Hans Dampfs so I used a tube to seat them first and after that they went up fine with the track pump. The only other comment I have is that the Conti's were super tight and an absolute bitch to fit.
Posted : 22/01/2015 9:35 am
My 35mm LB 29er hookless rims have been fine with spesh tyres and a track pump (apart from a leak around the valve)
Posted : 22/01/2015 10:51 am
My 26ers (33 or 35mm, can't remember) are a bit harder than most- not as hard as my fulcrums, harder than my stans or mavics. I've got a compressor but I've done at least one tyre on each with a pump, just to make sure I could.
Posted : 22/01/2015 10:54 am
Cheers guys thanks for your help. Glad to see it's not only me that has a problem with the Rail's OW. Don't know weather to sell the Rail's or strip and use the hubs which I like. Have seen some DT 350's straight pull for just over £150 plus postage,would like the 240's but they are more than double for a circa 60 gram weight loss.
Posted : 22/01/2015 10:59 am
Check availability on straight pull spokes first - better than it was, but can be a PITA still.
Posted : 22/01/2015 11:01 am
bizzare - my RR 2.1 went up with a track pump and single layer of tape!
Might have to give this a re think njee20, over £200 for the spokes 😯 Sapim Cx ray bladed.
Posted : 22/01/2015 11:17 am
try bike24 for spokes, my DT Revs for both wheels with nipples came in at £50
Posted : 22/01/2015 11:21 am
^^^^^^ thanks for that. Cheaper than my efforts
Posted : 22/01/2015 11:33 am
I'd steer clear of straightpulls in general but, if there's a CX-Ray there's probably a Laser. The difference is that the Laser is round, the CX-Ray is literally a Laser that's been squashed flat. Which also makes it a bit stronger, with the extra forging, but the Laser is still very good and a lot cheaper, and obviously the exact same weight
Posted : 22/01/2015 11:47 am
Was thinking bladed to try and eleminate spoke wind up, but will have a look at the Laser's. My Lbs,who will build the wheels (has done a few sets of Lb rims) prefers J bend but when he gave my Rail's a check over before a trip to Spain was quite impressed. In over twelve months the Rails's have been superb apart from tyre seating. I know I could just buy a compressor but fancy trying to drop the weight a little. Still have to do the sums for that one though.
Posted : 22/01/2015 12:15 pm
