Lezyne 'Alloy ...
[Closed] Lezyne 'Alloy Drive' pump probs
[#1040825]
Just had a go with my new pump to find it unusually hard going and I can't imagine it's normal.
I'm using the presta end on a Stan's valve and trying to inflate from around 10 to 30psi was like a mini work-out. I can't see what else I should do other than unwind presta valve nut, screw on hose and pump away.
From time to time the tire sealant clogs up the valve a little but everything seemed to be flowing fine when the valve pin is depressed and it was the same on all 4 Stan's valves I tried.
Has anyone else experienced similar problems?
Posted : 14/11/2009 11:44 pm
mine works a treat, pop back to your LBS and see if they can swap it?
Posted : 14/11/2009 11:46 pm
Maybe consider swapping it for something tried and tested rather than the latest and shiniest.
Posted : 15/11/2009 12:38 am
Slw, it's won pretty much every test it has been in which is why I had specifically hunted it down.
Although I admit it is the shiniest 🙂
Posted : 15/11/2009 9:12 am
Occasionally screwing the Presta adaptor on can also close the Presta valve itself especially if the valve is bent.
Apart from that mine works a treat.
Posted : 15/11/2009 9:19 am
I have just tried it with a spare inner tube and it works great. Just tried it on the Stan's valve again and it doesn't work, despite them looking identical (inner tube also a removable core).
Posted : 15/11/2009 9:31 am
I found these pumps awful, sold mine on ebay as my 5.99 one from Halfords works 10 times better... overpriced bling
Posted : 15/11/2009 11:41 am
Only used mine once but it was perfect - much better than my old Blackburn. Do you give the valve a quick press first to let a little air out to kind of unseal it?
Posted : 15/11/2009 12:40 pm
