Lefty/Cannondale se...
[Closed] Lefty/Cannondale servicing Lincolnshire Help required
[#5074640]
I've an issue with the headset on my lefty. My LBS has said its been overtightened and they are reluctant to smash it up as its sitting on a Ti frame.
I've been recommended to take to a Dale dealer but where on earth looks after leftys near me???
Help please
Ta
Posted : 16/04/2013 10:40 pm
Id start by asking a Cannondale dealer http://www.cannondale.com/gbr/dealer-locator and see where to got from there.
Posted : 16/04/2013 11:15 pm
Most LBS wont touch leftys as they never see them. They are however really straightforwards to maintain (a total faff tho - just follow the instructions TO THE LETTER) Popping one off the bike is easy enough - take off the top cap on the fork, loosen the top support plate, and the rest should be easy enough. Loads of info on the net to DIY - have a go!
Posted : 17/04/2013 12:29 am
Hmmm... Over-tightening sounds unlikely, as they don't preload like conventional aheadsets. What are the symptoms?
Posted : 17/04/2013 3:56 am
Depending on the type of stem and steerer on a lefty it usualy undo the Allen bolts on the upper or lore crown and knock through with a rubber mallet.
Posted : 17/04/2013 6:30 am
The bottom cap allen key slot has been rounded off. The prev owner has drilled holes into this cap to wrench it on/off by the looks of it. Bit of a bodge job :/ Bearing are knackered so need replacements.
I've found a new bottom cap. just need new bearings. Any ideas?
Posted : 18/04/2013 9:38 pm
I don't understand what you mean by bottom cap.
Is it the headset bearings or the four flat roller strip bearings you are trying to replace ?
Posted : 18/04/2013 10:58 pm
I remember reading a thread on here Oliver where there was a guy from Evans cycles claiming he serviced cannondale forks and was good at it. Might have been a Fatty he was talking about but worth a search anyway.
Posted : 18/04/2013 11:16 pm
Lefty 'headset' is just two cartridge bearings on the steerer and is a trivial issue IME, unless things have changed recently (not currently running a lefty). The fork itself is much more involved, but it sounds like that's not the problem?
Posted : 18/04/2013 11:26 pm
Sorry if I've been vague! The bearings are shot and need replacing but I can't get at them because of this
I've a new cap on order and this should be with me tomorrow I hope.
Posted : 19/04/2013 8:04 pm
Hmm I'm lost on that one, lefty steerer on mine was hollow so to take the headset bearings out you undid the two pinch bolts on the crowns and just tapped it out with a mallet. The steerer pulls out an fork just slides off sideways. Then you just tap out the headset bearings with a screwdriver.
What is this cap? I just had a plastic bung. What is it tightening on to?
Headset bearings are only available through a dealer too as no one else other than NASA use that size by all accounts.
Posted : 19/04/2013 10:40 pm
 dale
that looks like a steerer / conversion.My guess would be to start dismantling from the other end .
Posted : 19/04/2013 10:54 pm
What a pain in the arse! But finally done!
New question! How the hell do you get to the bearings? I've loosened off the bolts that clamp the fork to the head tube. Looks like its a one piece stem and headtube so should pull out right?
Posted : 22/04/2013 5:13 pm
have a look ere: [url= http://singletrackworld.com/forum/topic/cannondale-lefty-help-please ]stw knows[/url]
Posted : 22/04/2013 5:54 pm
There's also a Lefty appreciation society type thing on faceache that's got some service tips, vids and info.
Posted : 22/04/2013 6:04 pm
Cheers lads
Posted : 22/04/2013 6:19 pm
