Lefty Advice...
[Closed] Lefty Advice...
[#2724845]
Just bought myself an old Jekyll in really nice nick, all looks to have done very low mileage - however(!) the lefty fork makes a grinding noise upon compression and doesn't feel to smooth at all. I haven't has a set of forks for about 10 years so have no idea what I'm doing and my local bike shops don't really want to know. A quick Google search suggests that they use needle bearings which can sound funny, but I'm convinced this isn't right. Any ideas what might be going wrong here? Cheers!
Posted : 06/05/2011 5:09 pm
Speak to TJ or ernie ....
Posted : 06/05/2011 5:12 pm
Or more helpfully try Thumbprint or Noahs Ark
Posted : 06/05/2011 5:13 pm
It needs a service old bean, send it to TF Tuned.
Posted : 06/05/2011 5:14 pm
The needle bearings can have a slight rumbly feel, but shouldn't be grinding.
It's probably full of crap. They are great forks when serviced though 🙂
Posted : 06/05/2011 5:18 pm
cheers for the replies guys, bit of a pain as bought off ebay for a fairly premium price (been looking for a decent nick jekyll/lefty for ages!)and was described as being excellent all round - only just found out the guy used it to ride roads. looks like a pricy service is the way forward 😕
Posted : 06/05/2011 5:24 pm
You can lift the boot and give the stanchion some grease for now, so it's a bit smoother with the needle bearings. Probably need a bearing reset too.
Posted : 06/05/2011 5:45 pm
Jimalmighty - Member
TF Tuned only deal with the newer stuff, nothing as old one fitted to a Jekyll.
I can't recommend Tony @ Thumbprint enough, yes it's pricey as their not that common. I recommend you send them in to him to be checked over, but take a look at the price 140mm lefty's max are selling for on fleabay before commiting if it's gunna be a major rebuild, as a newer one (even if it need servicing) maybe a better investment
Posted : 06/05/2011 6:00 pm
 dale
go with noahs cheapest service around.Once done should be fine for a couple of years.They do work out economical.If youre handy with a micrometer try here http://forums.mtbr.com/showthread.php?t=221683
Posted : 06/05/2011 7:05 pm
which lefty is it?
some of the older air forks are hard to get serviced due to rarity of the tools
Lefty Max 130/140 coil sprung ones are not too bad to service yourself, spares could be a pain if required
if it's later than 2004/5 (ie metric) apparently you can use the latest internals as a straight swap out (not cheap)
mtbr forums are your friend
Posted : 06/05/2011 7:11 pm
I recently had my lefty serviced by Evans and it feels like a new fork now. Great service and convenient for local pickup which saved on postage (for me anyway). Highly recommended and reasonably priced too!
Posted : 06/05/2011 7:25 pm
