Lefty 2.0 bearing r...
[Closed] Lefty 2.0 bearing reset
[#9363404]
How often do you reset yours? Mine need resetting after every ride. Is that normal? I lose about 20mm travel each after each ride which a quick reset sorts out. Bit of a pain though!
Posted : 04/06/2017 10:55 am
Two or three times a year.
Posted : 04/06/2017 11:02 am
On my 140 every 2 months or so. On my 90 not once in 4 years.
Posted : 04/06/2017 11:49 am
Every couple of months.
Posted : 04/06/2017 12:09 pm
Not sure what lefty I had but I used to do it pretty much after every ride. It's only a 5 minute job so just became part of my post ride check/maintenance ritual. Was no big deal if I didn't do it for a few rides though.
Posted : 04/06/2017 12:38 pm
James, doesn't sound right that pal?
Posted : 04/06/2017 12:53 pm
Also is it the new 2 spring internal?
Posted : 04/06/2017 1:04 pm
Yep new 2spring upgrade. My mate has the same issue with his and has to reset it after every ride. Both have 2spring upgrade.
We both race XC and I'd say the forks get a proper hammering. Not sure if this contributes to it! Will try lower pressure see if that helps. Currently running 95psi and weigh 72kg.
Posted : 04/06/2017 3:41 pm
I'm 100psi at 75kg, also had the 2 spring upgrade, and have been faultless
Posted : 04/06/2017 4:03 pm
Have you measured the travel recently? The only reason I knew it needed a reset was because I measured the travel with a tape measure. It's hard to tell the difference through feel alone before and after a reset to be fair.
Posted : 04/06/2017 4:10 pm
No problem here, had it since October.
Posted : 04/06/2017 6:21 pm
James yeah full travel here pal.
Posted : 04/06/2017 6:45 pm
