Least chain sucky d...
[Closed] Least chain sucky drivetrain
[#3933287]
Hello,
After a particularly frustrating chainsuck problem with a Saint drivetrain across two very different frames, I have the opportunity to build up my Bfe with whatever set up I want: 1x9, 1x10, 2x10 or 3x or even Rohloff!
Apart from the Alfine/Rohloff which obviously comes with its own compromises, and singlespeed, which I can't handle, which would be the set up least likely to encourage chainsuck?
Was thinking 1x10 ...?
Bomus points for any kit which the STW has found to be reliably reliable with evil 'suck too (or the inverse!)?
Ta.
Posted : 01/05/2012 7:41 pm
1 x anything I'd have thought.
Posted : 01/05/2012 7:42 pm
I've only ever had chainsuck when a drive component is knackered tbh, not experienced it with one in good nick.
1x10 has simplicity in its favour - depends what you've got in mind for the BFe really. Great for messing about on, and even with a heavily-built one 1x10 would be ok for most xc riding for a few hours - it would only be the harder and /or longer rides where it would start to get on top of you.
I have a triple slx on mine - just something I slapped on it though, not given it real consideration.
Posted : 01/05/2012 7:50 pm
Thanks both.
So if I go for 1 x 10, I'd be interested in recommendations on reliable low-fuss kit - what do I need to buy? 🙂
Posted : 01/05/2012 8:01 pm
What (real) disadvantages does an Alfine have over 1xanything? (except possibly cost)
Posted : 01/05/2012 8:04 pm
The only downside I've found in 6 years of riding with hub gears is weight.
Posted : 01/05/2012 8:23 pm
Anything not worn and adjusted well
Posted : 01/05/2012 8:24 pm
Least chain sucky drivetrain = Single Speed
Posted : 01/05/2012 8:48 pm
Still open to helpful responses.
Posted : 01/05/2012 9:14 pm
It's a worn drivetrain not the frame FFS
Posted : 01/05/2012 9:20 pm
for 1x10 get a nice single speed chainring - eg Renthal (aluminium) or Surly (Stainless) etc etc.
Get a chain device - I am guessing ISCG05 for the BFe.
And then all the normal 10 speed rear gubbins. Probably go for an SLX cassette, mech and shifters unless you can afford Saint.
PS and yes chainsuck is either worn or damages component(s)or bad/poorly maintained set up.
Posted : 01/05/2012 9:22 pm
Steel middle rings often help. Shorter tighter chain might help?
Posted : 01/05/2012 9:38 pm
Thank you - very helpful.
Posted : 02/05/2012 9:36 am
*but sticking my fingers in my ears and head in the sand to all the correct ones*
Posted : 02/05/2012 9:50 am
