Leaky Reverb 🙁
[Closed] Leaky Reverb 🙁
 Twin
[#4635295]
My Reverb has started leaking air, When I put air in it, it keeps droppeing back to the 50 PSI mark, which isn't enough to get the post back to full height, but it will stay up if assisted to full height. Its leaking from the valve end, I can hear the air coming out, but not the valve (I've checked the valve). Anyone else had this, is it an easy fix? The post is still warrantied, but I don't want to be without it for long as it's a matchmaker clamp, so without it, I can't attach my brake & shifter! Its the siver collared version BTW
Posted : 09/12/2012 10:44 am
Warranty it. Likely to be away less than a week, mine was
Posted : 09/12/2012 11:23 am
 LoCo
As above warranty, the whole end cap which incorporates the valve stem is one part.
Saying that if you're local to us feel free to pop in an we maybe able to fix it there and then.
Posted : 09/12/2012 11:24 am
 Twin
Cheers for that. Warranty it is then. LoCo, I'm from Blackwood so will be round to the shop for fork seals soon, what are you open over Xmas?
Posted : 09/12/2012 11:29 am
 LoCo
Until the 21st then back in after new year, maybe in the 27 & 28th depends on family, will be putting opening times on the website.
As I mentioned the seat post maybe a really quick fix so it maybe worth dropping it in and we can check it there and then, it could be something as simple as a component coming loose.
Posted : 09/12/2012 11:34 am
 Twin
Cheers, I'm nghts tomorrow, so will try to pop in then!
Posted : 09/12/2012 11:47 am
