Largest chainring o...
[Closed] Largest chainring on M8000 crankset?
[#11445062]
Trying to use some spares for a commuter build. and have a M8000 (XT) chainset that I'll probably use, what's the largest chainring I can get on the cranks with a 96mm BCD?
Posted : 24/10/2020 5:15 pm
Superstar do 36t or snail ones off ebay.
Asym 96 bcd.
Posted : 24/10/2020 5:34 pm
38T - https://www.ebay.co.uk/itm/352832641391
Posted : 24/10/2020 8:57 pm
Sounds impressive:-
“Ergonomic shape utilizes the stampede acting efficiently to create more stampede traction”
That’s the biggest 1x option I’ve seen for those cranks though.
Posted : 25/10/2020 10:44 am
Superstar do 40t ovals
Posted : 25/10/2020 8:29 pm
Chainstay clearance?
Posted : 25/10/2020 10:02 pm
I've had an Aliexpress 38T on no probs, but as mentioned above chainstay clearance is likely to be the limiting factor.
Posted : 25/10/2020 10:13 pm
@montgomery thanks for the heads-up, I'll check that. Should be ok, frame's a commuter based Cannonale thingy
Posted : 25/10/2020 10:23 pm
