Large floor fan for...
[Closed] Large floor fan for zwift - with remote control
 Alex
I was under the impression that all Tuya/Smartlife devices wouldn’t work without “phoning home”.
Well I best add 'check my firewall settings' then to my list of jobs today 😉 I was going to re-flash them but thought Id found a lazy way round it. Maybe not.
Posted : 22/05/2021 1:30 pm
@Alex The only workaround I know of is a Home Assistant integration Called "Local Tuya" which works by pretending to be the cloud server, it's actually more hassle than just flashing the things as you have to create a dev account with Tuya, get an API key then use that to extract each device's local key. Handy for anything that can't be (easily) flashed though.
Posted : 22/05/2021 2:03 pm
I take it I'm the only biffer on Zwift that basically needs all the fans going at full blow within 5 minutes of the start of a race?😂
Posted : 22/05/2021 11:30 pm
It all sounds a lot more complicated than my long stick remote…
Posted : 22/05/2021 11:47 pm
I take it I’m the only biffer on Zwift that basically needs all the fans going at full blow within 5 minutes of the start of a race?😂
No, I do as well, and the window open and radiator off. Odd thing is most of the rest of the time I'm cold!
Posted : 23/05/2021 12:05 am
I just use an extension lead with switched sockets. #smashthemills
Posted : 23/05/2021 11:43 am
Page 2 / 2
