Hey, I have a 2011 zesty which has some play in the lower/rearward shock mount but I can't seem to track down the correct part.
I've previously swapped over the bushings for the joint between the seat/chain stays so not concerned about the technical challenge aspect.
The bush in question is sort of top hat shaped and I can't find it online anywhere. Initially I got a standard fox mount kit but it's nothing like what's on there currently.
Help much appreciated from anyone in the know!
http://www.ubyk.co.uk/lapierre-spicy-zesty-rear-end-bushing-kit/12477
Edit: Ignore me. Didn't read it properly!
Any pics?
Found it, I think!
http://www.tftuned.com/heavy-duty-mount-kit-127mm-m6/p2936
Yeah that's the type, i used to fit them quite regularly to bikes in the shop but can't remember the exact size you need, give TFtuned a call with your bike details and they'll know exactly what you need.
EDIT : if you want to slacken the front end then [url= http://www.burgtec.co.uk/category/products/offset-shock-hardware/ ]Burgtec[/url] do offset bushings so you can play about with the head angles.
http://www.mojostore.co.uk/acatalog/Fox_Rear_Shock_Bushing_Kits.html
I've got a Lappierre 2012 X Flow 612 with an RP2 and Fox have changed the old alu style for the ceramic. They do look totally different but are the correct ones. You need a tool to remove the eyelet which you can get cheap on eBay. The ceramic are press fit by hand with no need for any tools.
Thanks all!
If you are after either a standard bush or an offset one - you can get them for the bargain price of £10 including 1st class postage from www.offsetbushings.com.
Hope that helps!
Jeron
