KS LEV in 27.2mm Di...
[Closed] KS LEV in 27.2mm Diameter - Are they actually available anywhere?
There's a small cap between the grubscrew and the cable to protect it from any damage...
Posted : 02/03/2013 9:38 pm
Finally got around to fitting mine last night. Return speed is very slow. The construction seems to be the same as my 31.6 just the air valve is missing. Bit disappointed really compared to the larger version.
Not ridden it in anger yet and before anyone suggests to seat clamp is too tight, I've also proved it with the seat clamp loose.
Posted : 20/03/2013 9:56 am
Right then. I've managed to get it returning a good bit quicker.
The Kevlar cord was slightly too long. By the time the hook had pulled to the bottom of the chamber under the red cap, the plunger under the cap on the bottom of the post still hadn't been fully depressed.
All I've done is shortened the effective length of the cord my about 3mm and it's much happier now. Not lightening fast, but now appears "normal" rather than slow.
Posted : 24/03/2013 8:39 am
Page 2 / 2
