KS i900 adjustable ...
[Closed] KS i900 adjustable seatpost remote lever replacement?
[#1108425]
Anyone know where I can get a new one of these? I had it mounted topside on the handlebars, and after one (gentle) turning over to remove a wheel, the bottom part of the clamp broke off and disappeared. Wondering if anyone knows where I can get a replacement?
Apparently Crank Bros Joplin remotes and Rock Shox Poplocs work, but am unwilling to spend £35 and £65 respectively for such a simple thing.
Poop - am well chuffed with it otherwise.
Posted : 07/12/2009 2:58 pm
Probably easist to ask Pure Racing themselves if you haven't already;
http://www.pure-race.com/Contact.html
Posted : 07/12/2009 3:35 pm
Thank you muchly, I was trying to find contact details for the company, but was daftly searching for Kind Shock UK rather than Pure Racing. Will get in touch with them...
Posted : 07/12/2009 4:37 pm
Did you buy it from superstar?
Just email them. They were quick and helpful with the replies with me. They wanted £20 for the standard lever unit posted and £35 for the new ODI grip lockring style one. You use the magic pound coins bit and ask for the part in the comments box
Okay its a little steep when you only need part of it
You really should have mounted the lever below the handlebar though. Running on top was just asking for trouble. If you wanted to run it on the right and below, you undo one bolt and swap the lever to the other side
Posted : 07/12/2009 4:43 pm
