KS adjustable seatp...
[Closed] KS adjustable seatpost lever issues
[#5640464]
Anyone else had this ?
ks dropzone
seems a nice post but one ride in gritty welsh mud and the lever action has got really sticky and crappy, takes a load of force to try and move it
Posted : 27/10/2013 9:30 pm
The cable that came with mine was pretty poor so I replaced that almost immediately, but I think it's 3 scottish winters old now and still going strong with infrequent servicing and one replacement bushing.
Posted : 27/10/2013 10:45 pm
Mine worked flawlessly in all conditions... Clean it, lube it and make sure the lever clip isn't too tight on the bars.
Also worth checking the actuator on the saddle, occasionally needs a careful clean particularly with the Welsh silt.
Posted : 27/10/2013 11:02 pm
yup was the lever actuator under the saddle, clean and lube and its all nice again
cheers!
Posted : 27/10/2013 11:37 pm
I found that a small dollop of grease stopped that problem from re-occurring but I also recommend a rear mudguard to stop the mud from being able to get anywhere near it
Posted : 29/10/2013 11:12 pm
Not got a dropzone but a Lev. Works fine, as said the cable supplied is shite.
Posted : 29/10/2013 11:29 pm
under seat levers!
Posted : 30/10/2013 9:55 am
Lose the barrel adjuster to avoid dirt ingest and I fitted a rear mech barrel adjuster spring between the post cable stop and the lever. Found this helps take up any slack in the cable and stops the bar lever ratling.
Posted : 30/10/2013 10:26 am
Anyone have a tech tutorial to service it? Mines full of Welsh mud, the levers gritty and sticky.
Posted : 05/11/2013 5:08 pm
Well mine now seems to have died
Just stopped working last ride replaced cable cleaned out lever actuator which now has smooth action but post won't move / only moves very slowly
Serviced it as per the Ks YouTube video
(Was actually quite clean inside considering the conditions out there)
But it's still stuck
Anyone any ideas before it goes back ? (It's the same as i900 I think)
Posted : 18/01/2014 4:05 pm
