Kona Dew opinions &...
[Closed] Kona Dew opinions & sizing
[#2635757]
I need a new commuter bike. I can get a new Kona Dew for under £200 - but how do they size up? Evans says they are a compact frame size that come up 5cm smaller than stated. E.g. 56cm frame = 51cm
I'm 5'6", and ride a 16" Cotic Soul off road. The Dew has 700cc wheels, does that make a difference? Am confused by the use of metric, and funny sized wheels...
Anyone got one? Anyone know of something better for the price?
ta,
thebunk
edit - doh! Options are 45cm or 49cm...
Posted : 06/04/2011 9:26 am
got one and its been great, the only thing about 700c is being a bit more gentle with curbs and steps but it definatly rolls faster.
I am about 5'7 and ride a 16 inch simple... cant remember what size dew i have, ill go out and have a look for you!
edit- Right i run a 52 cm, and id be wary of going smaller as its would probably feel too short
humm mine is about 3 years old they might have changed the sizing system?
Posted : 06/04/2011 9:30 am
Cheers titusrider. Will probably go for the 49" then. Just found a Kona Smoke - the steel version! Choices, choices...
Posted : 06/04/2011 9:58 am
I have a 56cm Dew (5'11) and it's fairly short. By that I mean it's short but fine, because it's my pootler/commuter. Definitely not as long as a 56cm road bike would be. In fact it's shorter than my 53cm Kona road bike, but that's a funny compact frame also.
I love the bike btw - I have the standard cheapo version from 2007 or so - just gutted it doesn't have disc mounts as the next year's model did. Mine had strange grandad bars which I changed for a flat bar and 120mm stem I had lying around in the garage.
Does the smoke have 26" wheels? The older ones did. A Dew should be a lot faster than a smoke anyway as stock, with those tyres.
Posted : 06/04/2011 10:05 am
I have a 2009/2010 however it is the Dew Drop version, 5ft9" and a 54cm is totaly fine for me
Posted : 06/04/2011 10:09 am
Thanks for all your help.
Smoke is 29er too. I think I'll go for the Dew though, it will be lighter and has disc mounts.
Posted : 06/04/2011 10:28 am
