Knee pad silicone g...
[Closed] Knee pad silicone gripper repair?
[#11122655]
My knee pads have started to slip due to the silicone gripper coming away. The pads are in good nick so rather than throw them away, I was wondering?
1. Can you buy the stuff they use?
2. Anyone bothered with this and come up with a alternative that stays stuck to the material and does the job?
Hate throwing stuff away!!
Posted : 04/04/2020 12:28 pm
silicone bath sealant?
Posted : 04/04/2020 1:28 pm
Id find out what kind of silicon it is then google that then see if you can buy a flat sheet on ebay.
Cut a strip, then Copydex it on and if you have a seam roller for wallpaper in your toolbox, apply maximum pressure with that.
Posted : 04/04/2020 1:45 pm
Cut the tops off some hold-ups and see them on.
Posted : 04/04/2020 2:30 pm
Some good ideas here! will look into the stuff they use, if no joy will have a go at the other ideas. Cheers!
Posted : 04/04/2020 2:37 pm
There is only one answer.
https://i1.adis.ws/i/annsummers/04SKHUAS1213006_Z?$product-large$
You have to admit, it is exactly what they are for.
Posted : 06/04/2020 1:51 pm
I use this stuff to repair wetsuits and kayaking spray decks. Tough and flexible.
If you have run some on the inside and leave to dry it should do a similar job.
https://www.stormsure.com/adhesives/stormsure/stormsure-flexible-repair-adhesive-3-x-5g-tubes.html
Posted : 06/04/2020 3:29 pm
