Kids chainset and g...
[Closed] Kids chainset and gearing
[#10506099]
Got a Frog 69 MTB - a really good bike. Gets used weekly and the determination shown on the climbs suggests that it won' be long before I'll be shouting for a break to catch my breath.
However, the climbs are a bit of a struggle...the chainset is 140mm cranks and a 32t ring. It has a chainguard but I've not worked out how to replace the ring - it looks like it is a one-piece solution.
So I'm needing to find square taper 140mm cranks that can take a 30t narrow-wide ring. Narrow-wide as the mech doesn't have a clutch and I suspect the chain will bounce a fair amount.
I'm off to start trying to get Google to give me a solution, but has anyone else changed the chainset/ring on a kids bike and if so, what did you use?
Thanks.
Posted : 24/02/2019 10:38 pm
Think SJS cycles do some Thorn ones that go down to that size.
Posted : 24/02/2019 11:02 pm
 Yak
+1 for sjs. We have thorn cranks with 30t chainrings.
Posted : 24/02/2019 11:05 pm
Could you go bigger on the back?
I've put a 11-40 sun race 8 speed cassette on my son's frog 52. I bought a road link for the rear mech but didn't need it in the end.
Posted : 24/02/2019 11:47 pm
I use Suntour xct jnr cranks on my kids bikes. They’re only available in 152mm tho.
I binned the middle (heavy steel) ring and use a 30t n/w. The cranks are actually pretty light.
Posted : 24/02/2019 11:57 pm
Vpace out of Germany, or spawn.
Posted : 25/02/2019 12:06 am
I put trailcraft cranks on my lads bike. They have 140 and 152
Posted : 25/02/2019 7:07 am
Ideal, thanks for the pointers. The Tailcoat look nice, I found them after posting, but initial thought is a bit pricey as I may need a wider bottom bracket as well. (however, if everything similar is the same price then not pricey) Will check Thorn and SJS out, thanks.
Posted : 25/02/2019 8:00 am
Kids Racing is where you should be heading, these are what you want.
They go down to 135mm, have a narrow Q factor and are 104bcd so you can fit down to a 28t with spacers.
Posted : 25/02/2019 10:03 am
Ideal, thanks.
Posted : 25/02/2019 10:50 am
I didn't find any of the options much good, in the end I just went SLX 1x11 with a 46T rear. My daughter's bike has a triple up front - she can just about manage front shifting, but she's 7.
Posted : 25/02/2019 10:57 am
I got severe earache when I suggested adding a double at the front...so I'll do this and she can improve on the climbs without realising I've been tweaking the gearing.
Posted : 25/02/2019 2:08 pm
Heard back from Frog, the chainset is a 1-piece unit so can't replace ring.
So either new chainset with a 30t ring or maybe a wider range cassette.
Alivio SGS rear mech, 9spd cassette is currently 12-36, so looks to maybe need a SunRace 11-40 (but unsure if I'd need an adapter for the mech).
New cassette is cheaper and easier to swap over (unless an adapter is needed for mech then it adds a bit of time).
Posted : 25/02/2019 3:49 pm
