Kids 6 speed trigge...
[Closed] Kids 6 speed trigger shifters, are they available?
[#3644900]
My daughter has trouble with the twist shifters on her bike, can you get trigger shifters for a 6 speed? Cheap like.
Posted : 05/02/2012 9:42 am
 jonk
Triggers here
http://www.ukbikestore.co.uk/product/97/sltx506pa/shimano-sl-tx50-sis-thumb-shifter-plus---6-and-3-speed-pair.html
Or use a 7 speed but index from 6 so there will be a click to 7th but no change.
Posted : 05/02/2012 10:21 am
jonk +1
Posted : 05/02/2012 11:01 am
Be careful with a 7-sp shifter and a 6-sp freewheel or vice-versa.
Spacing is not the same and it will be difficult/impossible to get a good shift across the whole block.
I had this issue with a 6-sp indexed downtube shifter with a 7-sp wheel. It would not index, so I switched back to a 6-sp block.
Friction shift is never a problem, but your daughter may not be capable.
Check it out on Sheldon Brown.
PaulD
Posted : 05/02/2012 12:41 pm
having been in the same boat, i'd suggest a good clean and lube on the twisters first, and a nice new cable. If you girl is small she might have trouble with triggers plus they are not as straight forward in function as a twister.
Posted : 05/02/2012 12:45 pm
I am sure I have a new 6 speed shifter in the shop. Cheap but ugly though.
Posted : 05/02/2012 6:21 pm
