Kenda Nevegal size ...
[Closed] Kenda Nevegal size v's Schwalbe NN please
[#2073857]
Hi
Thinking of replacing my worn Kenda Nev 2.1 front, 1.95 back with a Nobby Nic/ Racing Ralph combo for something a bit faster. Does anyone that has both know a comparative size? Do they come up a bit smaller? Should I go for 2.25 front and 2.1 back?
Thanks
[Yes I know I should go down to my LBS but I need to get them for next weekend :-)]
Posted : 10/10/2010 4:10 pm
i have had racing ralphs they are ok i found rocket rons faster, i do have the super light ones and super thin tubes tho,
your LBS can order them for you, fishers are pretty quick at dispatching stuff.
Posted : 10/10/2010 4:22 pm
The Nobby Nics are exactly 2.25" measured a couple of says ago, i know im sad.
If the Kenda's are the right size, then the Schwalbes will be bigger.
Posted : 10/10/2010 4:26 pm
Thanks Swift - was that to the side of the Carcass or the outer knobbles (so to speak)?
My summer Panaracer Razer 2.3 looks about the same size as 2.1 Nev, but maybe I should get the tape measure out?
Posted : 10/10/2010 4:32 pm
To Side Nobs, but theres negligible difference, as the carcass is very....bulbous.
Maxxis come up a little small from my experience too.
Posted : 10/10/2010 4:34 pm
Cheers - it's the bulbousness that appeals TBH as I have been enjoying Razer front, Nanoraptor rear over the summer, both of which have a curved carcass.
Was considering a High Roller but that seems much more square shaped 🙁
Posted : 10/10/2010 4:43 pm
 br
Not sure where you live, but it ain't the weather for RR's now.
Posted : 10/10/2010 5:20 pm
b r - NN on the front, RR on the back ~ Quantocks BTW
Posted : 10/10/2010 5:29 pm
I've run a NN/RaRa combo all Summer and it's been great but had to swap the Ralph for a Dirty Dan XC this week as the RaRa was struggling in the wet and muddy conditions round here.
Posted : 10/10/2010 5:52 pm
I run 2.25 NN/RR all year, but worn through my RR, when i get another it will go on.
I like its performance in mud.
Posted : 10/10/2010 10:07 pm
I prefer the Schwalbe Fat Alberts
more to be compared to the Nevegals
Posted : 10/10/2010 10:20 pm
RR don't like mud, NN are better but the Nevs are much more capable in the mud
Posted : 10/10/2010 10:21 pm
