Got some new(ish) Pikes. They're fine at the moment, but was wondering what tips you lot might have for getting the best out of them? I've read too many stories of lots of forks dying within a few months. Should I store them the right way up, or upside down? Cleaning with a hose after each ride, but obviously not a high pressure jet wash. Bit of oil around the stanchions and seals? I found a tutorial on how to drop the lowers off and rebuild, but don't really fancy doing that too often!
Gareth
lower leg service
Teflon spray lube on the stanchions occasionally.
WD40 to make the black paint look nice. 🙂
http://dirt.mpora.com/news/how-to-maintain-your-boxxer-forks.html
Video is for boxxers but if they're coil pikes, the procedure is identical.
Cool, thanks for the video.
Any ideas about keeping them the right or wrong way up between rides? Heard something about keeping the seals wet with oil, but also that they can leak if left inverted...
cheers
Gareth
I've had Pikes a year or so and just lean the bike against a wall....
The most important thing to do is keep the seals and stanchions clean. I rub M-Prep onto the seals and stanchions every few rides too. Once applied I cycle the fork a few times and wipe off any remaining grease as it can attract dirt. My fork has no stiction at all.
I've had mine since late 2006 and never done a thing with them. Usual cleaning, fork oil on the seals and that's it. They're the coils and are still buttery smooth. Lowers are still in good nick and the stanchions show no signs of wear at all... Pretty much fit and forget...
as i recall store them the correct way up.
If they are coils? follow [url= http://pondering-panda.blogspot.com/2008/09/tutorial-fork-service-rockshox-pike-426.html ]my friends service guide here[/url]
and [url= http://www.juicelubes.co.uk/fork-juice/ ]fork juice[/url] on the stanchions after cleaning.
I like that Fork Juice lube. Very worth learning how to take the lowers off and clean the seals every now and then - maybe change the oil too.
It's very easy once you've plucked up the courage - not doing it is probably what knackered my Pike stanchions after a year or so.
If you've bought them second hand, I'd recommend doing a lower leg lube now. Firstly, RS don't always stick that much oil in from the factory, secondly you don't know what the previous owner did to them. It's really not a difficult job - 15 minutes is easily doable with a bit of practice, but well under an hour even for the first time. They'll feel amazing afterwards as well. Loads of suspension grease in the seals!
The lower leg service is easy but can be messy.
And compress them when upside down before riding to get oil into the bushings.
