KCNC PF30 bb chain ...
[Closed] KCNC PF30 bb chain line question
[#5721844]
Hi Guy's,
I've fitted a KCNC pf30 bb to a carbon covert frame. I'm running a single ring up front with an e-13 lg1 +.
The kcnc instructions were a little confusing as it at first advises running a 2mm spacer on the non drive side and then at the end shows the spacer on drive side. I believe shimano bb's also use a 2.5mm spacer on the drive side (not a 2mm as kcnc suggest) for a 73mm shell.
Basically, i'm having trouble getting the chain device to line up correctly with the front sprocket. The chainring is too far out if that makes sense? I'm using one black and one gold washer on the lg1, however if i use 2 black the chain device is then too far out!
Has anyone fitted one of these bb's, if so, what spacer configuration did you use?
Thanks
Hugh
Posted : 25/11/2013 10:07 pm
