just replaced coil ...
[Closed] just replaced coil with air shock - but there's a catch...
[#1661529]
So...the valve on the air shock (DHX 4.0) just snags on the rocker (turner 6pack '06) - literally just - so the shock must be less than 1mm from its uncompressed position! I did loads of research to get the right model - correct stroke and length etc...it is just a couple of swings with a round file away from fitting perfectly...but obviously that is a last resort!!!!
is there any way to either change the valve position or micro-adjust the length of the shock at all...the fox manuals don't seem to help.
Posted : 01/06/2010 9:21 am
 IA
Tried a lower-profile cap for the air valve? Like the plastic one off a tube? (which you could even file down a bit easily)
Posted : 01/06/2010 9:24 am
Can't you simply turn it around? Swap eye to eye, or turn it upside down?
Posted : 01/06/2010 9:26 am
yeah - it still just snags on the thread of the valve - actually I'm not sure what pressure is being put on the valve, not very much by all accounts - but it is close enough to be potentially damaging.
most folk just cut a notch on the rocker arm.
Spend a bit of time on the MTBR turner forum - there's plenty of information on there about it.
Posted : 01/06/2010 9:29 am
The rockers from that era have a little notch in them to allow clearance.
Personally I'd stick with the coil, but then I've never tried an airshock that I liked.
Posted : 01/06/2010 9:40 am
What you need is a Gonzo.
Not this one.
But this one.
I got mine from Mojo.
Posted : 01/06/2010 10:04 am
 IA
Ah yes, the Gonzo valve. Best part name ever.
Posted : 01/06/2010 10:07 am
I like it...and will probably buy it - but the rocker will still catch on the gonzo valve...
...reaches for the file...
Posted : 01/06/2010 10:13 am
It shouldnt catch because you can rotate the Gonzo so it is behind the shock. It doesnt stick out as far as the std valve. Look at mine on my pitch.
http://www.flickr.com/photos/29930426@N04/4388744903/sizes/l/in/set-72157623726748152/
Previously I had to remove the shock to add air as the valve was behind the rocker so tightly I couldnt even get the cap on it. With the gonzo I had plenty of room and routed it so it came out above the rocker as you can see.
Posted : 01/06/2010 10:27 am
I believe the use of a file is the sanctioned Turner mod for this situation... but as linked above, it's all there on MTBR, you just need to find it!
Posted : 01/06/2010 10:47 am
no - I mean - the valve seems to be directly under the rocker so the rocker is "just about" resting on the valve - which is not good...
however - your picture suggests that the valve position could be changed? is this possible on fox shocks?
Right I see what you mean.
The position where the valve comes out of the head cant be changed but the gonzo changes the angle. I cant remember if its slimmer than a normal valve but I would guess that its not so you will still have your issue. Although fitting a gonzo and filing the rocker so it fits around that will mean you will be able to put air in the shock without either removing it from the rocker or filing a lot more off the rocker.
Posted : 01/06/2010 12:00 pm
so rocker filing might be ok then? I'm hoping it will be no more than 1mm
Posted : 01/06/2010 12:44 pm
