Joplin remote kit i...
[Closed] Joplin remote kit instructions - anyone got them
[#4663529]
I've gone and lost mine, anyone have an electronic version or could scan one?
Posted : 18/12/2012 2:57 pm
what do you need to know?
Posted : 18/12/2012 3:04 pm
Need the instructions in totality really. The problem is I took the instructions out when I went to get tool I didn't have and then I'm not entirely sure where I put it.
Posted : 18/12/2012 3:08 pm
Small allen key screw in the lever - remove this
Un attach cable from lever pull on the seatpost
Push out cable which come out with gear nipple fron the lever
Install another one
rescrew allen bolt - attach cable to seat post
Posted : 18/12/2012 3:09 pm
bizarrely this is on the tech support page of crank bros site, who'd have thought it
Posted : 18/12/2012 3:34 pm
rob - sadly, smart arse, that doesn't cover the conversion from the lever to the remote. I could have a reasonable guess on the missing bits (as I could with JYs) but I'd much prefer the full instructions if anyone had them. Which was why I asked.
Posted : 18/12/2012 3:43 pm
they are the instructions that come with it.
Its easy:
screw on the cable guide in the hole on the back
knock pin out of the actuator on the seatpost head and remove the lever
put new actuator on and hammer pin back in
attach remote to bar
cabe thru cable guide on back of post, plastic cable cover over exposed bit
screw cable clamp down
done
Posted : 18/12/2012 3:49 pm
and it shows pictures of each bit and where they go - are you serious you cannot follow those?
Posted : 18/12/2012 3:50 pm
