JONES - truss fork ...
[Closed] JONES - truss fork judder?
[#5152581]
Anyone get brake judder when using their JJ truss??
Posted : 13/05/2013 3:58 pm
Not got one, so no, but have you checked there's no play in the headset?
Posted : 13/05/2013 4:49 pm
not on mine.
As above, is the truss preloaded on the headset enough?
Posted : 13/05/2013 4:52 pm
Nope.
You using a wavey rotor?
Are all the brake bolts tight?
Posted : 13/05/2013 5:16 pm
Nope
Posted : 13/05/2013 5:20 pm
No, rock solid always.
Posted : 13/05/2013 5:32 pm
No, 6 years on mine and still with the original head set, thousands of smooth miles ridden and still as good as new.
Posted : 13/05/2013 6:34 pm
Give you £50 for it;-)
Posted : 13/05/2013 7:21 pm
I haven't got one, but was thinking of of getting one, perhaps when JJ finally goes for the Ti Diamond 🙂
The Niner RDO I have at present gives some stutter/judder so was wondering if it's a rigid fork thing
I'll check everything - HS, rotor etc
Posted : 13/05/2013 7:43 pm
Ti forks coming soon and there's a diamond ti frame on the bay at the moment...bargain at £1850
Posted : 13/05/2013 7:46 pm
You'll never fit on a Jones you lanky streak of piss. 😉
Compared to every other fork i've used the truss is by far the stiffest so i think you'd struggle to get any kind of judder going on.
Posted : 13/05/2013 7:50 pm
😀 😯 If you can get your bellies in there, I can get my lanky frame in 8)
Posted : 13/05/2013 7:55 pm
The ebay frame is a 23" does that mean seat tube (not ETT)
Posted : 13/05/2013 7:56 pm
The curved toptubes help with the beer storage organ. 🙂
Posted : 13/05/2013 8:00 pm
So, 23" is a huge frame, no?
Posted : 13/05/2013 9:15 pm
23" is the ETT. Aren't all Jones frames one size?
Posted : 13/05/2013 9:35 pm
The ebay one is a Merlin, so there's a chance it's custom?
Having said that 23" is sounding familiar as the one size fits all JJ geo...
Posted : 13/05/2013 10:00 pm
Merlin used to make for Jeff- I think he did a 23 and 24 for a bit but now does just one size cus the geo is clever
Posted : 13/05/2013 10:04 pm
23 is the ETT.
It'd be way too small for you.
Posted : 13/05/2013 10:08 pm
Are you sure it's the fork? I've had occasional judder on my truss and my jones uncrown - common parts: brakes and wheels, I would put money on the brakes over the fork
Posted : 14/05/2013 9:16 am
I tightened up the steerer and was going to test things on a ride today, but I'm fair weather and it's persissting down...
Thanks
Posted : 14/05/2013 5:58 pm
I had judder from an XT 775 caliper and older 6 bolt Shimano rotor on a ti truss. Changed the rotor, pads, mount, the lot, still happened. Next I changed the brake for a newer 775 I had and it went, no judder at all. I concluded the fork is so stiff or I was able to brake that much harder with it that it was showing up an old brakes problems, worn pistons or something, that I never felt on the sus fork it was on before.
Posted : 14/05/2013 6:23 pm
I'm 6' 4" and have the 24" Merlin version, others at my exact same height have the 23. In retrospect I think I could have gotten away with the 23 too although I think Jeff says they're for those upto 6' 2"
Posted : 14/05/2013 11:23 pm
Thanks, only just seen your reply.
Good to hear as I'm on the sniff for one again...
Posted : 28/05/2013 9:53 pm
