Jones Spaceframe SS...
[Closed] Jones Spaceframe SS question
[#5037224]
To save experimentation, what width BB do I need for a SS setup.....
Ta.....
Posted : 06/04/2013 5:48 pm
Anyone?
Posted : 07/04/2013 5:38 pm
try here
Posted : 07/04/2013 5:39 pm
(variable scale depending upon planetary alignments)
Posted : 07/04/2013 5:41 pm
It's a 68mm shell.
If you plan on using a square taper BB the length will depend on what crank you use and what chainline your rear hub has.
It's nothing special though so just transfer the stuff from your old frame.
Posted : 07/04/2013 5:43 pm
got a normal (well pimpy weight weenie) 68 - 113 in mine
Posted : 07/04/2013 5:53 pm
 joop
got a CK in mine, just set and forget..
Posted : 07/04/2013 8:23 pm
"It's nothing special though so just transfer the stuff from your old frame"
Karate Monkey, but I'll go for 113, I have one of those. Ta Tazzy..
Paul rear hub, Middlleburn Uno chainset.......I should have said.
Posted : 07/04/2013 8:56 pm
The KM has a 73mm shell so that's no good for the Jones.
Posted : 07/04/2013 8:59 pm
will all play nicely
just use a couple of spacers like wot the 68/73 bb's come with. Funnily enough thin SS spacers work just fine 😀
Been a long time since I've fitted a square taper BB. 😆
Posted : 07/04/2013 9:11 pm
