It's a little story where I bought a Pitch in Nov '07, started upgrading it blah blah blah ended up with Fox 36 Van R's, Hope Hoops, Fox DHX 5.0 Air, Double n' Bash repeat to fade.
It's a bit "Overbiked" for most things I do and I don't think it helps that it's got ST Highroller on the front and a Maxpro on the rear, round the likes of Llandegla etc it drags like a good un, the bike doesn't weight that much (31-32lbs).
Do I:-
a) MTFU
b) Stick a set of Advatage 2.25" on there for more rolling-ness (?)
c) Flog the frame and forks and build summit else
d) Swap/Sell the Forks and put some 140mm jobbies back on there (probably combined with option [b]b)[/b])
e) Any other ideas on a limited budget [i]i.e.[/i] 2nd hand frame stley option
just swop the tyres! HR's at llandegla....! why?
change the forks
Paul,
Generally I CBA to change the tyres 😆
Brakes - that answers one question, saying that though the Van's are barely heavier than coil pikes, we're talking about 100g's
Llandegla - you'll be reet on some Racing Ralphs, preferably in a tubeless guise, an outer ring and you're there. The forks seem a bit much on paper - but they ride great (presumably) and weigh naff all more than the alternatives, so best hang onto them IMO.
Rotating weight is the thing to sort, I reckon. It's also relatively cheap so resolve, in part with tyres. Happy pedalling.
Looks like it's Advantages or the 2.35" Ignitor Exceptions I've got sat in the Shed then.
I hate not being able to make my mind up
