Has anyone used j - tech to tune their suspension, how did it perform afterwards??
I've had several things done by them with very good results. A fox rp2 was serviced and tuned with a shim stack to give it the same feel as a push tuned one I had before. It gave more support and didn't blow through it's travel so easily. Big thumbs up from me.
Had a couple of m8's forks done there, for a std service which he did exactly that & they've come back and worked fine...
Would happily use him again.
Thanks for your replies, I'm getting the length and stroke adjusted on a RP23 to fit my old Stump Jumper as it has an irregular size afr shock.
Any other input very welcome:)
ex-pearce cycles mechanic I believe, with a good if understated reputation IIRC.
[url= http://dirt.mpora.com/news/young-rippers-bikes-harry-barretts-j-tech-suspension-scott-spark.html ]Dirt article[/url] on a special he did..
Had my lyriks and rear shock done a few weeks ago, great service.
Also had my lyriks and rear shock done a few months ago - excellent service - made it very convenient. Also custom tuned the lyrik to ride higher in it's travel - worked a treat and the fork is very supple now but without diving too much.
Intend to use them again and recommend them to others!
Would highly recommend James at J Tech, nothing is too much trouble and the advice is excellent.
