I've lost a my...
[Closed] I've lost a my bearings - What are my options?
[#4029497]
Due to a dog who I am no longer friends with, I've lost two ball bearings from my Cane Creek headset. Is it possible to buy just two or will the whole thing need replacing?
Posted : 01/06/2012 4:19 pm
 Taff
you can get singles but if replacing those then you may as well replace the lot. What size do you need do you know?
Posted : 01/06/2012 4:22 pm
Grow a pair? 😀
Posted : 01/06/2012 4:23 pm
Taff - Member
I'm not 100% sure. Is there an idiots way of finding out?
Posted : 01/06/2012 4:25 pm
Dog mechanic? Bit ruff with the headset was it?
igmc.
Posted : 01/06/2012 4:26 pm
Forgot to mention, it's a 1.5 headset.
Would this do the job? - http://superstar.tibolts.co.uk/product_info.php?cPath=61&products_id=439
Posted : 01/06/2012 4:27 pm
Whereabouts in Italy are you?
Posted : 01/06/2012 4:28 pm
I *might* have some kicking around, I have a knackered 1.5 reducer Cane Creek headset. They might all have turned to mush though.
Posted : 01/06/2012 4:30 pm
 Taff
Is it a sealed system that you have lost the bearing out of? If so then the bearings should have some numbers in black text on the side.
Posted : 01/06/2012 4:35 pm
Simply fashion new ball bearings from aluminium foil
Posted : 01/06/2012 4:38 pm
they will be stock sizes more than likely - measure them or take them to your LBS / motor factors / halfords
Posted : 01/06/2012 4:40 pm
How would I measure them?
Posted : 01/06/2012 4:49 pm
vernier caliper or micrometer... though if you take em to you LBS, they should be able to match them up (assuming you have a good LBS that stock spare BB's)
Posted : 01/06/2012 4:56 pm
Just buy a new bike
Posted : 01/06/2012 5:17 pm
Just wait for them to come back out and give them a good wash!!
Posted : 01/06/2012 5:19 pm
I had this problem..it's an easy fix...have a look at the back of the cupboard there'll be one of these there somewhere
http://www.britishsupermarketworldwide.com/acatalog/info_34026.html
If not it's probably just a short trip to tescos
Posted : 01/06/2012 5:23 pm
nice to see I wasn't the only one thinking along these lines... 😆
Posted : 01/06/2012 5:52 pm
