Its easy when you k...
[Closed] Its easy when you know how
[#2570794]
Inflating a standard tyre on standard rim using a trackpump
I was pumping away furiously in the garage (?!), nothing.. Then watched the clip above. Soapy water and the push down on valve method worked first time with 1 long stroke of the pump.
That was on a very loose fitting Rampage sport tyre. Heres hoping it holds its air..
Posted : 16/03/2011 10:26 pm
