Isopropyl alcohol
[Closed] Isopropyl alcohol
[#1837188]
Is it any good as a disc cleaner?,only I've run out of cleaner,and I've got a can of the above.
Ian
Posted : 27/07/2010 5:00 pm
yes
Posted : 27/07/2010 5:03 pm
oh yes
Posted : 27/07/2010 5:06 pm
Why do people use special stuff to clean discs?
Washing up liquid when cleaning the rest of the bike is perfectly good; it works on plates, and you eat off them..
Posted : 27/07/2010 5:10 pm
But plates dont need to be completely grease free.
Personaly I go for the 'dont clean them' option, just wash arround them and leave well alone.
Posted : 27/07/2010 5:11 pm
Last I checked, dinner plates aren't known for their stopping power.
Yes, very good, but... don't clean them unless there's contaminates/oil on them, the rotors have deposits of pad material on them through use, this helps the brake bite the rotor. clean rotors aren't great at stopping.
Posted : 27/07/2010 5:15 pm
Until you brake a couple of times....
Posted : 27/07/2010 5:21 pm
Nail varnish remover (acetone) should be very good at removing grease. but keep it away from paint and the calipers.
Posted : 27/07/2010 5:31 pm
Get some car brake cleaner spray from your local motor factor - about a fiver.
Posted : 27/07/2010 5:45 pm
1.80 at europarts
Posted : 27/07/2010 7:16 pm
No doubt someone will be along in a second to tell us that car brake cleaner has oil in it. Hopefully just for once they'll have an example of one this is actually true for :mrgreen:
Posted : 27/07/2010 7:36 pm
Allegedly some car brake cleaner has oil in it. 😛
The only time I've seen evidence of this was after I sprayed most of a can over an old rust bucket of a bike to get the encrusted crap off the mechs etc.
After it evaporated there was a massive oily patch just in front of the front door, although I suspect it was just the solvated crap left behind after the cleaner evaporated.
note: do any spraying away from the hawk like eye of the other half.
Posted : 27/07/2010 8:17 pm
I've used Muc Off motorbike disc brake cleaner on my bike - seems exactly the same as the mtb stuff but a quid or two cheaper.
Posted : 27/07/2010 8:50 pm
I never clean a disc rotor unless I've been working on the bike and there is a risk of contamination. the more pad material that gets deposited on the surface the better!
Posted : 27/07/2010 9:00 pm
Dinner plates stop very well when thrown against a wall.
So does an MTBer hitting a tree 🙂
Posted : 28/07/2010 5:43 am
Aaah, but are they wearing a helmet?
Posted : 28/07/2010 8:46 pm
