islabike front whee...
[Closed] islabike front wheel bearing size
[#5734398]
Hi,
Just overhauling my son's cnoc 16. The front bearings are pretty rough so I am going to replace them.
does anyone know what size bearings the front wheel takes?
Thankd
Posted : 29/11/2013 8:22 pm
I'm fairly sure the bearings are a standard hub bearing size (9 of 1/4" balls each side IIRC, though best to check Sheldon). The problem you'll have though is that you'll probably find the cones are worn (as is the case with the one I got s/h from my sister) and they are a non-standard item, including a bearing shield (not a seal, hence why the bearings are worn).
Posted : 29/11/2013 8:46 pm
...I checked and it seems I was remembering rear hub bearings: http://sheldonbrown.com/gloss_ba-n.html#bearingball
Posted : 29/11/2013 8:49 pm
thanks aracer, the fronts are pretty ropey, did you manage to source a new cone BTW?
Posted : 29/11/2013 8:57 pm
No - I just adjusted as best I could. It maybe they're not actually that difficult to get, but I never bothered.
Posted : 29/11/2013 10:02 pm
Front hub std is 3/16"
Posted : 29/11/2013 10:05 pm
Braved it and took it apart based on having some 3/16 and 1/4s in the draw. And as advised above they are both standard. no damage to the comes and now running like new!
Thanks for the help
ND
Posted : 29/11/2013 10:20 pm
