Am thinking of doing the Trans Cambrian Way in June.
Was wondering whether it is doable with a Bob trailer?
We met someone that was halfway through doing it with a trailer.
I've also ridden about 75% of the route and can't think of any of it that would be a problem.
Thanks for the quick reply.
Only issue might be the train back then, with 3 bikes and 3 trailers!
As long as you don't mind lifting it over the odd gate/fence, etc you'll be fine.
I hate those odd gates.
No where near as nice as the normal gates. 😆
Yeah plently do-able - only problem part I can think of is a small section of 10m or so steep single track on the middle of day 2 (we did it over 3 days in the summer just gone).
If it's only 10m then should be easy enough to push/slide/fall down!
For those that have ridden it, is the TCW worth doing?
