Where can I get an IS to IS 180 rear disc mount for Magura marta?
Do you mean a plus 20 mount? an IS caliper does not require a mount on an IS frame unless you want to increase the rotor size and still use the same caliper - the caliper defines the rotor size
Sorry when I say mount I mean adapter for a 180 disc. That's why I was saying IS to IS, I do know that IS callipers come in 160 standard. Sorry for the confusion.
IS calipers come in a varienty of sizes - depending on the disc size. (140mm - 200 mm) If you have an IS caliper with a 160 disc and you want to go to a 180 disc you need an is / is plus 20 adaptor - or the correct calliper for a 180 mm disc.
http://www.chainreactioncycles.com/Models.aspx?ModelID=13736
Cheers for the link! I was looking for the marta size 16 rear adapter to no avail, there apparently hard to come by reading the Magura forum. I take it this just works the same. I thought all IS callipers were standard 160 mounts and just used adapters, never seen any others, not to say they don't exist.
I have is mount brakes on all my bikes without adaptors - 203 to 140 mm discs
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21526 ]This is the Magura version[/url] though the Hope version TJ linked to above will do just as well...
Chain Reaction also do a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=42978 ]Shimano[/url] Version too, which is £1.50 cheaper, but is currently out of stock...
Each will work exactly as required...
I looked chainreaction site and didn't see them! Need my eyes checked I think. Cheers for the links. Out of curiosity what brakes are they TJ? I have only ever used Hayes and Shimano and have been biking 18 years now but cant recall all the mount types, I did have one old set of hope 2 pots on my Orange MR O years ago that may have had them.
sherry - hopes.
I would buy magura for magura brakes as i have had issues with hope and others not fitting properly
