Is this Normal - Ho...
[Closed] Is this Normal - Hope Hub Q
[#8030325]
This is a Pro 2 Evo
Normal wear and tear?
Note. The file marks on the outside edge are mine trying to get the cassette off
Posted : 01/09/2016 8:45 pm
Yup
Posted : 01/09/2016 8:46 pm
Yup. Soft as cheese and fairly loosely toleranced so the cassette digs in quickly. It does take a lot of wear before it becomes a problem, though.
Posted : 01/09/2016 8:49 pm
The notching on the splines?
Yes. But I'd use a cassette with an aluminium spider. Doesn't dig in anywhere near as much. Just give it a light dressing with a small file.
and do the lockring up 'FT' A loose(ish) cassette can also cause this.
Posted : 01/09/2016 8:54 pm
Just file down the burrs before refitting the cassette. To reduce this in the future use a non steel cassette or replace freewheel with a steel one
Posted : 01/09/2016 9:02 pm
OK, thanks
The cassette was a bugger to get off though
Interesting the mention of tightening up pretty tight to reduce the issue
Posted : 01/09/2016 9:10 pm
So what's the best combo to use - both steel?
Posted : 01/09/2016 9:11 pm
Don't tighten more than 40NM
Posted : 01/09/2016 9:20 pm
I use a chain-whip on the smallest gear to hold the freehub still and then give the rest of the cassette a gentle knock anti-clockwise with a rubber mallet to push the cassette back out of where it's dug in.
Cassette will come off easy then 8)
Posted : 01/09/2016 9:24 pm
40nm is pretty damn tight in my books!
Posted : 01/09/2016 9:46 pm
Good advice from Rocketdog. Over tightening will crack the freehub.
Posted : 01/09/2016 9:51 pm
