Is this crack fatal...
[Closed] Is this crack fatal?
[#4055756]
I've just noticed a crack under the seatclamp on my Chameleon, should I:
A) Keep riding it and hope for the best.
B) Retire the frame.
C) Try to find an aluminium frame repairer (Any suggestions?)
Posted : 11/06/2012 8:35 am
How much post do you run in the frame?
Could you get the frame cut at the crack and lower the seat collar? (not a professional opinion just a thought)
Posted : 11/06/2012 8:39 am
Plenty of post left in the frame, I did look at cutting it but the seatclamp would overlap the top of the tube.
Posted : 11/06/2012 8:42 am
I'd keep riding it.
If it failed completely you are unlikely to die, unless you have to ride 25 miles home with the saddle in the lowest position.
EDIT: cut it and put the slit at the back so the top tube not an issue?
Posted : 11/06/2012 8:45 am
would drilling 2 small holes at the end of the crack stop them spreading any further ?
I'd get it to a frame repairer. Maybe even put a gusset around it and place a new slot at the front.
Sorry, don't know any specific repairers
Posted : 11/06/2012 8:51 am
Any decent fabrication shop that works alloy should be able to fix that. Hole drilled either end, weld and then probably need toream the tubbe to get it round again. Then fit a bolt up seat clamp around that area after filtering away the lip or get a proper deep clamp made
The stw favoured repairer..... http://www.argoscycles.com/
Google has more
Posted : 11/06/2012 9:04 am
How old is the frame?
If still under warranty take it back.....
Posted : 11/06/2012 9:23 am
You could also look at double height seat clamps that would go over the damaged area. Repair would be better though.
Posted : 11/06/2012 9:27 am
Looks like its had the wrong size post in there at some point and clamp tightened. I would probably cut the tube down.
Posted : 11/06/2012 9:33 am
It's a 10 year old frame so well out of warranty, I think it's just fatigue from the QR seatclamp.
I don't think Argos do Aluminium repairs but did find [url= http://www.vernonbarkercycles.co.uk ]this guy[/url].
Posted : 11/06/2012 9:45 am
given that the cracks have originated from another small hole and the end of a crack, I suspect not 🙂
Posted : 11/06/2012 9:48 am
It could end up making a nice fractal pattern though.
Posted : 11/06/2012 9:50 am
You sure you're post is the right size for the frame. A touch small perhaps? The crack are right where the stress concentrations would be if the post was too small/large and the circle was being compressed/expanded around its circumference.
Posted : 11/06/2012 10:06 am
The seatpost is definitely the correct size, I think it's the constant seat dropping that's caused fatigue.
Posted : 11/06/2012 10:09 am
This will fix it.
Posted : 11/06/2012 10:21 am
This will fix it.
I was going to use this:
but that looks far more professional 🙂
Posted : 11/06/2012 10:28 am
Why?
Posted : 11/06/2012 10:32 am
Why?
Constant undoing and tightening of QR. But I'm no expert, do you have a better explanation?
Posted : 11/06/2012 10:39 am
[i]do you have a better explanation[/i]
the seatpost is slightly undersize or the seat tube slightly over - the top of the seat tube is beign compressed more than it's designed too and causing stress at the bottom of the slot leading to a fatigure crack as you can see.
Posted : 11/06/2012 10:41 am
Time to buy a dropper post as well then!
Posted : 11/06/2012 10:44 am
No, seatpost is the correct size, a nice tight fit.
[i]a nice tight fit. [/i]
then you're overtightening your QR 😉
Posted : 11/06/2012 10:45 am
Possibly, but any less tight and it slips.
Posted : 11/06/2012 10:51 am
Been surfing a porn site and without realising switched to STW and saw the title 'is this crack fatal' 😯
Posted : 11/06/2012 10:52 am
Could there be a tiny bit of a 'lip' on the lower part of the seat clamp, that's biting into the seat tube - causing a 'stress riser'?
Posted : 11/06/2012 10:54 am
If it's a perfect fit, tightening the clamp should generate naff-all stress there - even if you were a complete gorilla with the clamp and somehow compressing the tube through its thickness (grrrrr!), the hole should still see no signficiant stress.
Something else is going on here - my money's still on undersized post 😉
Posted : 11/06/2012 11:11 am
27.2 Thomson post in a 27.2 seat tube, how exactly is that under size?
Posted : 11/06/2012 11:14 am
easily, as the seat tube slightly to big, and seatpost slightly to small (which can happen with Thomsons)
Posted : 11/06/2012 11:27 am
It is possible to buy a 27mm post - though they are not that common now and not sure Thompson ever made them in that size. Seen similar damage with people running 27mm seatposts in a 27.2mm frame and thinking 0.2mm would make no difference although you state that's not the case here.
Posted : 11/06/2012 11:28 am
Face it OP, it's your fault!
stw says so 🙄
Posted : 11/06/2012 11:36 am
I had one of the same era (and even the same colour) fail in the same way. Mine had an Easton EA70 post of the correct size.
I know of 2 others of the same era that failed there.
Perhaps no coincidence that the next versions had 34.9 seat-tubes for 30.9 posts rather than the 31.8 for 27.2 that was used on that version. Stronger, but less comfy!
Posted : 11/06/2012 11:45 am
as richc says, tolerances. Ive just had to ream the BB of new ally frame as the threads were too shallow to take a BB, probably worn tooling and one of the last to come off the line before they changed cutters. Not "your fault" but a plausible and reasonable explanation given the evidence.
Posted : 11/06/2012 11:49 am
stw says so
I know it's my fault, it's always my fault 😉
[b]@sillyoldman[/b] did you get the frame repaired, or retire it?
You couldn't physically get a bigger seatpost in the frame, it's just not possible. #floggingadeadhorse
Posted : 11/06/2012 11:59 am
Alright then - everything is perfectly in tolerance, perfectly aligned and within tolerance. Hmm.... it must be pixies then.... yep, pixes, in the night, with tiny little pixie files, filing out those two cracks night after night, micron-by-micron. B@stard little creatures of the night they are......
Posted : 11/06/2012 12:27 pm
+1 on Argos cycles.
We also used Prodrive (WRC rally guys) to fix an Ancilotti DH race bike once.
Posted : 11/06/2012 1:14 pm
OOH get her! and her Hand bag!
Can it be fixed - yes. how much do you want spend?
A Argos repair and respray is going to cost you £100+
Slicing the top off and drilling a new slot - nowt.
Its your call, but i know what i'd do with a ten year old frame;-)
Posted : 11/06/2012 1:20 pm
 Taff
I had this on a Rocky Ridge and it was fine for a fair few years until I scrapped it. Didn't really go much further than yours.
Posted : 11/06/2012 1:22 pm
[img] ?rand=630365908[/img]
Plus some rattle can touch-up paint and it'll be good as new!
Posted : 11/06/2012 2:00 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=48590&gclid=COLInfSoxrACFcwNtAod2DgzVg ]Try one of these![/url]
Posted : 11/06/2012 2:45 pm
