Is this bolt not ri...
[Closed] Is this bolt not right?
[#7910237]
Pivot Mach 429sl frame only about 10 rides old.
All the bolts are set like concrete, so I suspect threadlocked and frame is totally solid and silent, bike rides ace, but I don't like the look of this bolt.....
What do you think? Time for a coffee and strip down?
Wally.
Posted : 26/06/2016 11:23 am
That does look like considerably more play behind the bolt that I would have thought was acceptable, I assume it's a lot tighter the other side?
If so it's definitely worth further investigation, perhaps before stripping it down email Pivot with those pics?
Posted : 26/06/2016 11:27 am
I'm not familiar with those frames but could it be a spacer or a bearing with a shoulder.
Posted : 26/06/2016 11:29 am
Look like "36" two bolts should screw into each other?
Posted : 26/06/2016 11:45 am
If it's the same as the bearings on my other halfs Mach 5.7c, which that diagram supports, the bearings have an extended inner race, essentially acting as a spacer, which is what gives that gap. Does he other side look the same?
It looks about right from memory
Posted : 26/06/2016 11:51 am
You are talking about the gap between the inner face of the link and the frame, right?
Posted : 26/06/2016 11:52 am
Yes the gap, although I am glad I am asking whilst having a coffee, because the other side is bob on and the block is a solid lump, so it must be a spacer I have never noticed before?
Posted : 26/06/2016 12:05 pm
