Is this a good idea...
[Closed] Is this a good idea.Washing out a shifter
[#6978407]
Wash out an xtr m970 shifter with a good solvent and then re-apply a wee bit of spray grease to it.
This sort of stuff.
[url= http://www.ebay.co.uk/itm/WD-40-High-Performance-White-Lithium-Grease-Aerosol-Lubricant-Spray-WD44391-/281398139555?pt=LH_DefaultDomain_3&hash=item4184a2daa3 ]link[/url]
Or do you need to use a light oil.
My front one is sticking on release.
Cheers all..
Posted : 04/04/2015 9:17 pm
That problem's generally caused by a small pawl sticking on it's shaft (probably dried up grease), usually easily cured by removing the cover, applying a drip of GT85 on the shaft, and working the pawl free with a little screwdriver or similar (random spraying isn't as likely to go where it's needed, and doesn't adress the need to work the pawl free).
Posted : 04/04/2015 11:02 pm
If this makes any sense coatesy.
Iv,e had it opened up a couple of times and it works great with only a wee bit on tension and the pawl is free.Soon a you load it up with a chunk of pressure(shifted onto mid front) when you go to release it there's two clicks.First one is a small click and nothing happens.Then you really have to push it to get to drop a cog...AAARRRR.Pain in the arse...
Posted : 05/04/2015 12:10 am
 JoeG
I usually use WD-40 to clean out sticking shifters. Its much less likely to damage plastic or rubber than something like carb cleaner. I then use a silicone spray to relube.
Posted : 05/04/2015 5:41 am
Just tried that Joe.Still the same.I think some wee bit inside is well and truly buggered.Time for the bin.
Posted : 05/04/2015 7:43 pm
