Is there much diffe...
[Closed] Is there much difference with a 26t & 36t inner & middle chainring?
[#464708]
Have just recieved some new chainrings a 26t & 36t inner and middle, I normally run with a 22t & 32t and have ordered these in error & just realised my mistake. I'm not the fittest and do use bottom gear fairly frequently on the steepest of hills, and I just wondered if I am better sending them back or is there any advantage in running with the bigger ratio?
Posted : 11/04/2009 5:04 pm
22, 36 and bash is a nice set up for a short chain and mech with a normal cassette.
Failing that there's usually people in the classifieds looking for 36T middles so you could probably swap without much bother.
Posted : 11/04/2009 5:06 pm
Same here.
I've been trying out a 36t middle - but have decided to go back to 32t as I'm finding it much harder to climb in middle cog with a 36t.
Posted : 11/04/2009 6:05 pm
I run a 26/36/bashring set-up on one of the bikes and haven't had any issues gearing wise, depends where and how you ride really.
Posted : 11/04/2009 6:07 pm
24/36 and bash here with 32/11 on the back, works just fine...
Posted : 11/04/2009 6:18 pm
22-36 gives the best of both worlds and works fine.
Posted : 11/04/2009 6:42 pm
what rings are they? i could be interested in them. if you decide you don't want them try me at paul.keavney1@ntlworld.com
Posted : 11/04/2009 7:54 pm
22 / 36 here - all the gears I need. I would struggle with a 26 granny ring.
Posted : 11/04/2009 8:14 pm
 ton
hey big lad, send em back or order some walking shoes for the uphill bits...... 😉
Posted : 11/04/2009 8:15 pm
26-38 when I run a double.. I don't really climb many hills anyway!
Posted : 11/04/2009 8:26 pm
Try it, if the only option you get used to it
Posted : 11/04/2009 8:31 pm
44-36-26, 11-27 on the back
Posted : 11/04/2009 8:35 pm
I was needing a new cassette anyway so I stuck a 34-11 on and the bike pedals pretty well & I can get it up the usual steep stuff with a bit more effort + you seem to get better range from the larger rings requiring less faffing with changing at the front.
Posted : 19/04/2009 2:46 pm
