Is there any case h...
[Closed] Is there any case history of cyclists being prosecuted for riding on a footpath
@Rich_s you can't serve an injunction against someone just because you don't like what they are legally doing. Walking a pedal cycle on a footpath is a legal activity.
Suing the individual if they were trespassing is also very difficult to prove any loss.
It just isn't going to happen unless the civil trespass is against some well financed organisation. Which the local farm is not.
Posted : 05/04/2021 10:27 pm
I think you haven't realised which question I was replying to.
you can’t serve an injunction against someone just because you don’t like what they are legally doing
I didn't say they could.
You don't need to prove a loss. As previously said a few times in the thread.
It just isn’t going to happen unless the civil trespass is against some well financed organisation. Which the local farm is not.
Agreed. We've been discussing the theoretical side of trespass as a tort rather than whatever the hell is going to happen in the real world.
Posted : 05/04/2021 11:19 pm
You don’t need to prove a loss. As previously said a few times in the thread.
Ok, so you may be able to sue for some gain the other party made by directly interfering with your land (but which didn't cause you a direct loss per se) although I don't know the case law on this. I guess this would be an indirect loss or something? In the case of riding or pushing a bike down a path, I'm not sure what this could be?
Posted : 05/04/2021 11:41 pm
Nope, just by coming onto your land, the trespasser is preventing you from your legal 'enjoyment' ; which is a loss. So you could in theory calculate a rate of that and claim accordingly. I'm pretty sure though you'd struggle to get a name and address from them...
 In the case of riding or pushing a bike down a path, I’m not sure what this could be?
This is the point that's never been tested. Conventional wisdom points to the above, ie it's their land and by coming onto it riding a bike, you're trespassing...But, the law also says the footpath is a public space, and there's the plaguey rub: could you claim trespass if the cyclists sticks to the PROW? It would probably cost quite a lot, (more than for which you can claim trespass) and it's not at all clear if you'd win.
Posted : 06/04/2021 1:40 pm
 Ewan
My understanding of trespass, is that the landowner or their agent can ask you to leave the land - you do that by the nearest exit (you don't need to retrace your steps). If they want to stop you doing it again they need to get an injunction, which they can only do if they have your name and address. They have no right to demand your name and address. So if you're trespassing in some random wood, be polite and seek to leave by the nearest exit if asked, but other than that don't worry about it.
Posted : 06/04/2021 2:26 pm
Just tidying up a few legal points
The "cause of action" of trespass does not have causation of loss as part of it. It is unlike negligence or fraud in that sense. But to bring a court case you need to claim a remedy (and if you fail to get a remedy from the court you will have lost the case). Any remedy depends on proving a wrong has been committed.
Apart from damages (which requires some loss even if only loss of enjoyment etc.) an injunction or declaration are possible. A declaration would be appropriate where you refused to acknowledge the owners right, but normally an injunction would be the better one for a landowner to go for. Both are equitable remedies so at the discretion of the court. But in practice an injunction would likely be granted if you did not promise not to do it again when the landowner's lawyers wrote to you.
There is quite a bit of confusing case-law on when the court can refuse to grant an injunction when infringement of a property right is proved. So it is possible one will be refused in a genuinely accidental one- off incident.
I am not dealing with the intricacies of the law of trespass here as it is not my area. Or was not.
Posted : 06/04/2021 8:51 pm
@greyspoke
Could a possesser get an injunction from a judge without going through the process of actually suing? Or would this be limited to temporary injunctions pending court case?
Posted : 06/04/2021 10:10 pm
Good question @i_scoff_cake. The answer is no, you always have to issue a claim before the court will grant any remedy*, including injunctions. The court assumes that you will wait until the full trial of the case before granting you any remedy. But if you can demonstrate (with supporting evidence) that justice will be defeated** unless you are granted an injunction earlier, you can ask the court to grant you an injunction before (and lasting until) trial (an "interim injunction") but you will have to tell the other parties you are applying for one and argue it out with them at a hearing. And if you can similarly demonstrate that you need an injunction without first notifying the other parties, then you can ask the court to grant you an "ex-parte" injunction, but you will have to justify your application in an "inter-partes" hearing a bit later to get the injunction continued (so such an injunction would be very temporary).
If the particular facts support it, an interim injunction could be appropriate in a trespass case, but there would have to be something urgent, or some particular type of loss arising from it that meant the landowner could not wait for a full trial. If you regularly run rampage across someone's back garden or their crops I am sure the courts would be sympathetic, but for a typical "occasionally using a track that isn't a right of way" type case, the landowner will have their work cut out I think. But these things are very fact-dependent.
The phrase used in lay-peoples language "to take out an injunction" is misleading - only judges can grant injunctions, and they always need persuading that one is necessary. Injunctions can never be obtained by an administrative process, unlike judgments for the payment of money which can be obtained automaticaly, for example if a claim is not defended.
* Where it is important to keep the very existence of litigation secret, the court may grant an injunction if you promise to issue a claim once the injunction has been served. This is a slightly separate issue from what goes on with a "super injunction".
**This gives a flavour of it, the precise legal test is a bit more intricate. The problem in all these cases is, the court is having to second-guess the trial outcome on incomplete evidence, and what happens if it gets that wrong? There was a time when much of my livelihood derived from getting these things, it is tricky and despite considerable legal safeguards built in to the law and procedure, injustice can result (whether an injunction is granted or refused).
Posted : 07/04/2021 1:10 pm
This thread has turned out much more interesting than I anticipated...
Posted : 07/04/2021 1:35 pm
I think things might be changing regards trespass laws? Wasn't there something in the new Policing Bill that turned trespass from a civil to a criminal offence?
Posted : 07/04/2021 2:08 pm
If you're doing it with 2 or more vehicles or are a traveller, though really that bit of the bill is about making it illegal to be a traveller and very little to do with trespass.
Posted : 07/04/2021 2:44 pm
Page 3 / 3
