I have a set of XTR brakes with IS mounts but my new Fox forks are post mount. Can anyone recommend an adaptor - my LBS said it cant be done with Shimano?
I know I'll be needing a 180mm disc instead of the current 160.
thanks
Posted : 28/06/2010 2:03 pm
Shimano do this mount:
http://www.chainreactioncycles.com/Models.aspx?ModelID=13744
Which means you would have to get a 170mm rotor.
I'm in the sam eboat and need an adaptor to get up to 203mm and i think only A2Z make them.
Posted : 28/06/2010 2:07 pm
170mm rotor? Not seen that size before. Hope only do 160 or 180 though....I'm running Hope floating rotors with my XTR brakes.
Posted : 28/06/2010 2:12 pm
170mm:
http://www.chainreactioncycles.com/Models.aspx?ModelID=756
This might work for 160mm to 160mm:
Posted : 28/06/2010 2:19 pm
Posted : 28/06/2010 2:20 pm
Posted : 28/06/2010 2:27 pm
