Is my rim dead?
[Closed] Is my rim dead?
[#3949524]
I just noticed that my rear rim has a dent in it and is slightly flat looking with the two nearest spokes very loose. Is this terminal or something that can be fixed?
Posted : 07/05/2012 10:32 am
Probabaly terminal from the description.
Posted : 07/05/2012 10:43 am
it's not likely to go back to being perfectly round, if you've flattened it off that much. The question is, do you care? A couple of my wheels are permanently out of round but they still work perfectly well. And my old MTX31 was more dent than straight but they averaged out 😆
Personally I'd restore the tension and see what happens but you might prefer to go do a decent wheelbuilder.
Posted : 07/05/2012 10:55 am
Hmm I thought as much. I really need to be more careful on those cross drains. I'm amazed it didn't pinch flat.
Yeah I'll probably replace it but keep it as a spare as it's rideable. The wheels not that old so it would be a shame to chuck it. It is/was a good wheel too build by a good wheel builder.
I'll probably buy a wider wheel and put a bigger tyre on it for more rocky routes and avoid dumping my back wheel into cross drains again.
Posted : 07/05/2012 10:57 am
 tron
I flattened an on one reetard rim on my back wheel, it was too flat to get the spokes tight again, rode about on it for absolutely ages (at least a couple of years) and it didn't die. Eventually replaced it with a new wheel just for peace of mind.
Posted : 07/05/2012 11:13 am
