I've just put the brake rotor back on a wheel. One of the bolts is not tightening properly - it gets quite tight and then loosens, the other 5 are fine. Is this safe / safe-ish / Ok for a pootle but not a big ride / deadly?
BTW It's the front wheel.
It'll be fine*
*probably. I've done this and it was fine. Some pros even ride with only three bolts. However, I'm not responsible if you do it then die in a tumbling ball of bent tubes, rotors and flesh.
You'll almost certainly die. Don't say I didn't warn you.
*omits to mention the time he rode all day with the sub-frame hanging off. Without noticing*
Steve Peat did several races last year with only 3 bolts holding his 6 bolt rotor in place. It was hardcore riding, but then it was only for about 3 or 4 minutes.
Cheers for the advice.
I think I'll risk it for a couple of hours this evening, then fix it properly.
Hate to break this to you but you've probably threaded the hub so I'd get used to riding with 5 bolts 🙂
You will die - at some point. Everyone does.
Hopefully you will be fine, my hope hoops only have three rotor bolts per hub. Five sounds excessive to me 🙂
I've had a threaded bolt on my front rotor for about a year. I've not died.
Steve Pete may only ride for 3-4 minutes but I bet he puts his bikes through more punishment in those minutes than most of us do in a year.
