Is it worth changin...
[Closed] Is it worth changing to sintered pads?
[#569506]
Moved to disc brakes for the first time about a month ago and the brakes came with organic pads as standard. Just wopndering, is it worth changing to sintered and keeping the organic pads as spares? What difference woudl I expect?
Thanks!
Posted : 21/05/2009 11:04 am
where you ride has a significant impact
Posted : 21/05/2009 11:09 am
sintered will last longer esp in winter...I'd use the organics for the summer though.
Posted : 21/05/2009 11:23 am
Ah ok, so primary difference is longevity in crappy conditions?
Posted : 21/05/2009 11:24 am
Sintered can squeal too much which puts me off. SS organic pads are cheap as chips which swung it for me.
Posted : 21/05/2009 11:35 am
poppa - for me, yes. I think there are other minor differences too but that's the biggie.
Posted : 21/05/2009 11:36 am
I used resin for a year or so and then changed to XT discs that come with sintered pads.
Resin wear out faster but they work miles better, i'll be changing back to resin.
Posted : 21/05/2009 11:37 am
if you ride somewhere like the peaks, the grit quickly eats your kit, and sintered stands up to these conditions better.
Posted : 21/05/2009 11:44 am
