I have a SRAM X0 2x front shifter, and the paddle for dropping to small chainring has become stuck - it won't move. I took the top cover off and peered around all the scary flat and coiled springs - from a total guess it seems that the paddle might have come out of it's hinging mount, as it moves a little bit but not in the right way.
I found the below on eBay, leading me to suspect it is at least in theory possible to do this, but not sure if it is doable by a mere mortal who doesn't have tweezers for fingers.
Any ideas? Otherwise it's off to the FS forum to find a replacement shifter.
[url= http://www.ebay.co.uk/itm/SRAM-X0-Front-2-x-10-Speed-Shifter-Upper-Lever-and-Pin-38182-/281713200851?pt=LH_DefaultDomain_3&hash=item41976a4ed3 ]http://www.ebay.co.uk/itm/SRAM-X0-Front-2-x-10-Speed-Shifter-Upper-Lever-and-Pin-38182-/281713200851?pt=LH_DefaultDomain_3&hash=item41976a4ed3[/url]
They are fixable...you may lose the will to live in the process and they usually fail again shortly afterwards.
I've repaired X9 rear shifters before. It is a pain but doable, there was a bit that kept popping out when I was reassembling though so it used a little bit of weak glue to hold it in place, worked a treat. Can't remember which bit it was mind. There's some useful youtube videos that might help.
